Re: Running Problem
Posted by JOSSETTE on April 08, 2005 at 04:00:16 from (216.114.223.196):
In Reply to: Re: Running Problem posted by Ron in Nebr on April 07, 2005 at 23:12:37:
had I read it closer-- we are working with the diesel engine???
check the timing of the punp and static timing first..
if it sat for a while, throw some additive in her that will lube the injectors and pump...
you just may have some old fuel that has jelled 4 or 5 times and it does not have what it takes anymore........get old out and try some new???
Post a Followup
