Re: Heli Coil
Posted by Bob M on April 08, 2005 at 08:29:15 from (151.190.254.108):
In Reply to: Heli Coil posted by Charles Park on April 08, 2005 at 07:46:45:
Charles - If I understand you correctly you’ve got side frame bolts twisted off flush with the block casting. If so you’ve got several options:
If you’re gonna remove the busted bolts by drilling them out, you can simply drill and tap the holes for the next larger screw size. Then drill out the mating frame rail holes to accept the larger diameter and install oversize cap screws. This would be cheapest.
Or you can drill out the holes, tap ‘em for helicoil’s and install new capscrews same size as the originals. But you’ll need to buy a special helicoil tap and a helicoil insertion tool in addition to the helicoil “springs” themselves. (FWIW properly installed helicoils are more difficult to strip out than the original tapped theads. I've used 'em and they work great)
However before going to all that trouble you might engage the services of a good welder. By welding a large nub on the end of the bolt, then grabbing it with a vicegrips, very often the stuck bolt will twist right out. (The extreme heating that occurs during welding does wonders to break impossibly stuck threads). I’ve had excellent luck over the years with this method.
Good luck!
Post a Followup
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
