Re: Heli Coil
Posted by janicholson on April 08, 2005 at 08:37:09 from (199.17.6.175):
In Reply to: Heli Coil posted by Charles Park on April 08, 2005 at 07:46:45:
If your drilling efforts are very centered in the broken bolts, I mean within about 1/32" or less than a mm) and streight (perpendicular to frame) then I would use progressively larger drill bits to enlarge the hole until there is only the threads left. This requires several drills and patience, as well as a hand magnifier to be sure you are looking at the beginnings of the threads usually on one side, due to being a bit off center. Next is to dose the hole with penetrating oil and heat the casting with 1 or 2 propane or mapp gas torches to get it to ~ 250 degrees. Then using a sharp pic tool (dental type)get under a thread and start working it out like a spring. This leaves original threads (run a good tap in them, and they are where they belong!!
Heli coil is used when the internal threads are gone (excess drilling, or pulled threads). If there is a need to heli coil, the frame will need to be removed to allow the appropriate larger drill to be used (before removing be sure to pre drill with a bushing in the frame hole to get the helicoil drill centered perfectly).
JimN
Post a Followup
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
