Re: 660 where do you add oil to the rear end?
Posted by Tom Graham on April 08, 2005 at 16:30:25 from (67.137.115.186):
In Reply to: 660 where do you add oil to the rear end? posted by Sonnyday on April 08, 2005 at 09:34:41:
Three cornered cover plate just right of the gear shift, loosen and remove 3 cap screws and take the plate off. Power steering is also fed from this reservoir. Check the leve by removinf 1/2" pipe plug on the left side just below the clutch linkage.
Post a Followup
