Re: starting an H
Posted by Yugrotcart on April 08, 2005 at 18:11:16 from (70.50.50.196):
In Reply to: starting an H posted by 23 Grampian on April 08, 2005 at 17:40:54:
Are the battery cables and connections in good shape? Try puting power to the starter direct with a pair of jumper cables. If 6 volt you will need #1 or larger cables. I can barely crank my W6 by hand,lots of compression, with new 1/0 cables my 6 v system turns her over no problem.
Post a Followup
