Re: Ticking sound in the rear end on my 44 H?
Posted by tanner clark on April 08, 2005 at 18:55:35 from (69.243.11.105):
In Reply to: Ticking sound in the rear end on my 44 H? posted by Tanner Clark on April 07, 2005 at 10:10:54:
Ok I checked for the sound with the clutch engaged. There was no ticking or clacking noise with it engaged. The PTO and the belt pulley was disengaged fully also. I checked the fluid level for the trany with the little plug on the left side, and sludgey oil came out, but no water, so I guess that is a good thing. Do you think I should just change out the oil and see if that makes the difference, or should I check out the rest of the possibilities first?
Post a Followup
