Re: starting an H
Posted by old on April 08, 2005 at 19:42:29 from (207.69.136.201):
In Reply to: starting an H posted by 23 Grampian on April 08, 2005 at 17:40:54:
I'd start by putting some tranny fluid in each cylinder, that loosens things up and stop dry start problem. You may have a rust ring that is stopping it from turning over. And as the other guy said go right to the starter with your power to start with, that way you get max volts/amps just to get it to spin the first time
Post a Followup
