Re: starting an H
Posted by Michael Soldan on April 09, 2005 at 10:53:30 from (66.203.172.221):
In Reply to: starting an H posted by 23 Grampian on April 08, 2005 at 17:40:54:
Grampian, I agree with "Old", rermove the spark plugs, lube cylinders with tranny fluid or oil and leave the plugs out, spin the motor over, via the starter or jack it up and rock a rear wheel. When you have good "spin", replace the plugs and work on fuel/spark for the actual start.....good luck from Mike in Exeter Ontario
Post a Followup
