Re: overhaulin'
Posted by janicholson on April 11, 2005 at 11:43:59 from (199.17.6.175):
In Reply to: overhaulin' posted by Matt in MI on April 11, 2005 at 10:14:57:
Plastigauge is really only usable on known round journals (the smooth metal of the crank). using it on a journal that has had issues is not advised. Use a micrometer that is dependable, and check the journal diameter in at least eight locations. Around the journal in three locations, and similar locations toward front and back of engine (not in the middle of the journal). All dimensions should be within .0005" to consider the journal good enough. If it is not in spec. it has been possible around here (MN)to get them polished on the tractor. If not it is regrind time (at least for that journal). a new bearing on a eggshaped journal will not hold up at all.
JimN
Post a Followup
