Re: Ring compressor problems
Posted by Allan in NE on April 11, 2005 at 18:53:10 from (148.78.243.26):
In Reply to: Ring compressor problems posted by Todd L on April 11, 2005 at 18:44:15:
Hi Todd,
It can drive ya crazy sometimes. I put the bands of the compressor as close to "straddlin' the rings as I can. Then absolutely pull the fire outta that tightener.
Then, after dropping it in the hole, tap the compressor down against the block to square it up. Lean on that compressor to keep pressure against it, tap the piston, tap the compressor square again, tap the piston, tap the compressor, etc, ect. all the while keeping pressure downward on the compressor.
Also, I always soak the piston and rings in oil just before putting on the comressor.
Hope this makes sense.
Allan
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
