Re: Ring compressor problems
Posted by captaink on April 12, 2005 at 07:23:49 from (66.115.214.56):
In Reply to: Ring compressor problems posted by Todd L on April 11, 2005 at 18:44:15:
I just want to add a couple more thoughts to the fine list here already. Some ring compressors have the compression bands offset towards one end of the compressor. Make sure that these bands are on the end of the compressor closest to the block when installing the piston and that the compressor is tight on the block all the way around.
Second, if you are putting new rings on a used piston, double check the ring gap by taking a new ring and putting it in the cylinder to make sure the ring is not an oversize. Use the piston to push it to make sure the ring is perfectly aligned perpendicular to the cylinder wall. If the ring gap is correct, then make sure that all the ring grooves in the piston are absolutely clean with no deposits left to prevent the rings from compressing into the pistons.
Good luck!
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
