Re: W6 Carb Settings
Posted by P Backus on April 12, 2005 at 22:53:41 from (66.181.141.7):
In Reply to: W6 Carb Settings posted by Yugrotcart on April 12, 2005 at 15:17:36:
Hey tractor guy!-backwards
My I&T manual is a little sparse on the details, so I'll do the best
I can.
The screw near the bottom of the bowl is the main jet fuel screw.
Turning it CW makes the mixture leaner.
The screw on the upper part of the carb, but below the throttle
plate area is the idle adjusting air screw. Turning it CW makes
the mixture richer.
The screw on the carb end of the shaft (tube) coming from the
governor is the idle speed screw.
As far as initial settings, it sticks in my mind that 1 to 1and a
half turns out on the screws should get it to run, and then tweak
it from there. Maybe someone else knows better. The idle screw
can be left alone until it all is running good, then just adjust it
until you get a nice idle speed.
Paul
Post a Followup
