Farmall Tractors Discussion Board
Re: Putting water pump on Farmall C
Posted by Stan(VA). on December 08, 1999 at 09:21:22 from (207.79.164.6):
In Reply to: Putting water pump on Farmall C posted by Irv Plitzuweit on December 08, 1999 at 08:42:12:
You can order a rebuilt pump for a Super C but beware that it woln't include the rear body of the pump (They expect you to use your old one). So order a rear body from a salvage yard at the same time if you can find one. And while you're at it order an upper radiator neck from the Super C also which will give you a spot to plug in a temp sensor and a thermostat. You don't want a water pump without the thermostat or it will never warm up to operating temp.
Stan(VA).
Post A Followup
: Re: Re: Putting water pump on Farmall C
