Farmall Tractors Discussion Board
Re: Farmall M with unidentified control cable
Posted by Lloyd on December 08, 1999 at 09:41:15 from (199.120.84.154):
In Reply to: Farmall M with unidentified control cable posted by John on December 08, 1999 at 09:20:53:
If this is an overdrive and it"s stuck in high, you should have 5th gear locked out. Your PTO should also run fast.
Post A Followup
: Re: Re: Farmall M with unidentified control cable
