Farmall Tractors Discussion Board
Re: Farmall M with unidentified control cable
Posted by Jim on December 08, 1999 at 11:00:31 from (199.240.128.80):
In Reply to: Farmall M with unidentified control cable posted by John on December 08, 1999 at 09:20:53:
what you have is an early cable controled M&W 9speed transmission If you want to replace the cable you can get atruck pto control cable and cut to length. But you will have to remove the top cover to put in a new cable.
Post A Followup
: Re: Re: Farmall M with unidentified control cable
