Re: 460 87 or 93 Octain
Posted by Danny H on April 15, 2005 at 08:29:55 from (68.110.220.22):
In Reply to: Re: 460 87 or 93 Octain posted by the tractor vet on April 15, 2005 at 07:47:03:
Sats on IH 460
Engine Bore x Stroke
IHC 6-221 Gas 3-9/16 x 3-11/16
Rated RPM
1800
Compression Ratio
7.2 : 1
Weight
5650 # (actual)
7.2:1 compression ratio has no need or use for high octate fuel.
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
