Re: F12 Magneto
Posted by John M on April 15, 2005 at 18:40:35 from (64.53.74.20):
In Reply to: Re: F12 Magneto posted by Kevin Hood on April 15, 2005 at 13:44:42:
Just how do you use the starting crank? If you have the crank pushed in,pulling up from 9:00 it will only click once if you pull it up towards 12:00,that is not one full rotation of the crankshaft.(Unless when you pull it up youre pulling the hound out of it.)Knowing how you try and start the tractor may help determine what your problem is.
Post a Followup
