Re: Set fingers on pressure plate
Posted by Michael Soldan on April 17, 2005 at 19:14:39 from (66.203.172.221):
In Reply to: Set fingers on pressure plate posted by KEVV71 on April 17, 2005 at 19:05:49:
Kevv71, there are usually jam nuts on the bolts that set the fingers, loosen them off and turn the bolt to make your adjustment, usually turning in. The important thing is that all fingers are adjusted to the same degree about3/16th or thereabouts, as long as they are all the same. I haven't done a W9 but the H's and M are about the same as the W9 in configuration and again all fingers need to be the same as close as you can get them. When you are satisfied with the adjustment, tighten the jam nuts back up. I am assuming there is a belly pan on the 9 to work through. Good luck from Mike in Exeter Ontario
Post a Followup
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
