Re: c steering shaft
Posted by TDK on April 17, 2005 at 20:29:50 from (152.163.101.13):
In Reply to: c steering shaft posted by Bill Geer on April 17, 2005 at 19:11:21:
Remove the roll pin from front u-joint and pull joint from shaft. The steering worm shaft doesn't need to be removed to take bolster off. If you're going to rebuild bolster, then worm will screw out from front, after removing woodruff key from rear of shaft.
Post a Followup
