Re: water in rear-end
Posted by Slappy on April 18, 2005 at 03:41:07 from (143.88.86.44):
In Reply to: water in rear-end posted by railroadgoat on April 18, 2005 at 02:52:40:
No oil at all? If you had nothing but clear water I might consider removing the deck and having a look. More than likely though, you had some water followed by a "chocolate milk" fluid come out.??. If the tractor sit outside (and even if it doesn't) water finds its way into the rear end. Drain the fluid, pore in 3-4 gallons of kerosene and drive it slowly in 1st for 2-4 minutes (don't put any load on it or let it get hot). Drain it again - if the fluid is filthy repeat. When the kerosene comes out pretty clean, refill with 90 wt and you should be good to go. With oil prices as they are you can expect to drop some change on both kerosene and oil (it take 6 gallons)to re-fill. After a good cleaning you can also probably expect to change a lot of the seals (transmission shafts, breaks & axels), because the kero and new oil will remove all of the gunk that was previously plugging the leaks. After the cleaning, change your fluid every year if the tractor sits outside or you use it hard, every 2-3 years if it is inside and you use it for light work. If you take care of the transmission and use it correctly you will likely never have a problem with the rear-end.
Home
| Forums
Today's Featured Article -
Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
