Re: CaseIH 885 brakes
Posted by Bernard le mécano on April 18, 2005 at 09:53:36 from (207.134.117.62):
In Reply to: Re: CaseIH 885 brakes posted by DanTo on April 17, 2005 at 20:58:09:
Hi Dan, you can remove the piston without the tool, just screw 3, 1/4 NC bolts, with a flat washer. Pull with a nail hammer, each bolts, a few pull. It have 3 O rings per brake, 2 on the piston and one for the carrier, wich hold the differentiel. Put grease on those O rings before assembly. I have a tool to push the piston in place, I give you some pics of the tool, it's easy to make, with flat bar. I will send those pics today, after work.
Bernard le mécano Québec Canada
Post a Followup
