Re: farmall c fuel problem
Posted by Hermit on April 18, 2005 at 10:03:39 from (69.21.48.44):
In Reply to: farmall c fuel problem posted by JOE COSTELLO on April 18, 2005 at 09:14:48:
Can you get it to continue to run by closing the choke? Then it's a fuel restriction problem somewhere. If this tractor has a distributor ignition vs. mag ignition, have you check the ballast resistor? If the ballast resistor is bad and the tractor has been set up with a start bypass, then the tractor will start and run until you release the starter switch. Once you release the starter switch, there's no power to the plugs and the engine dies. Just some thoughts.
Post a Followup
