Re: B-275 diesel utility tractor, good tractor??
Posted by Mark L. on April 19, 2005 at 05:48:00 from (172.142.137.80):
In Reply to: Re: B-275 diesel utility tractor, good tractor?? posted by kjm on April 18, 2005 at 19:26:16:
I called the fellow that owns it back, he came down to $1850 firm on it. I also found a IH Farmall 300 utility for around the same money, I think I am going to buy that one instead, as I already have a 300LP. Thanks.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
