Re: B with a valve tap
Posted by Ed H. on April 19, 2005 at 18:19:25 from (216.93.123.47):
In Reply to: Re: B with a valve tap posted by Ed H. on April 18, 2005 at 20:46:00:
yeh....many of these old engines have been rebuilt a couple of times with piston/sleeve kits , and the old connecting rods were never re-bushed and honed....the bushings are cheap, but they should be pressed in, and must be honed to fit each piston pin....which leaves your tractor torn down for a couple extra days, ....maybe the old boys did'nt have the time or knew enough to do it
Post a Followup
