Re: 53 cub charging low
Posted by Bob M on April 20, 2005 at 04:11:06 from (151.190.254.108):
In Reply to: 53 cub charging low posted by DANWV on April 19, 2005 at 19:32:02:
Dan - If you only see 8 amps with the generator F terminal grounded and the engine at full speed, the generator has a low output problem. It normally should give 12 - 15 amps or so. A couple of possibilities:
1 - If the generator has an adjustable 3rd brush, reset the 3rd brush closer to the brush nearest to it. The closer the two brushes the higher the output. (But set no the 3rd brush no closer than 2 commutator bars from it's neighbor.)
Note that later production generators have a fixed (non-adjustable) 3rd brush.
2 - Could be the generator is suffering from an open or short in a armature winding, high resistance in the field winding, etc. The generator then needs a rebuild.
3 - (Long shot...) Could be the wiring between the generator A terminal, the cutout and the ammeter is too small or has high a resistance somewhere (bad terminal, etc). If the wiring is questionable it should be replaced.
Good luck!
Post a Followup
