Re: W-4 driving now but further problems
Posted by EricB on April 20, 2005 at 05:39:33 from (216.209.84.11):
In Reply to: W-4 driving now but further problems posted by Tom R on April 18, 2005 at 18:31:58:
You have lots of advice on the fuel problem. I use an in line filter as well. I also have had points that don't want to stay adjusted.
Steering slop is a common problem and is wear on the steering gear. At the base of the steering shaft there is a cover on the right side. If you open this there is a gear wheel and a worn gear. If you take the gear wheel off and rotate it 180 you will have the worm gear ride on "new" teeth. This will get rid of 90% of the wobble.
Post a Followup
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
