Re: 51 M won't crank/start anymore, HELP!!
Posted by El Toro on April 21, 2005 at 04:04:49 from (205.188.117.138):
In Reply to: 51 M won't crank/start anymore, HELP!! posted by Granger on April 20, 2005 at 21:55:12:
You probably need to charge that battery and see if the engine will start. Once you get it started put the volt meter leads across the battery terminals and see if that generator is charging. Should have over 7 volts to 7.5. That battery could have a weak cell. You should use a hydrometer to measure the specific gravity of each cell and they should be close. A reading of 1275 is very good and if one cell reads 1100 and the rest read 1270 - 1275 the battery needs to be replaced. If there's a drain on the battery and you can not locate the problem you can install a master disconnect switch in the ground cable of the battery this will isolate the battery from ground when you are not using the tractor. Be sure to shutdown the engine and shutoff the ignition switch before shutting off the master switch. Hal
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
