Re: Woodruff key on PTO
Posted by Michael Soldan on April 21, 2005 at 06:23:38 from (66.203.172.221):
In Reply to: Woodruff key on PTO posted by J.D. Palmer on April 20, 2005 at 16:03:23:
JD, Chris, Captaink, maybe I am misunderstanding the set up that is the problem, but the shaft end that has a keyway should of course never shear or break, the shear pin that is the safety feature should be at the opposite end of the shaft..at the tractor pto...so the way I am picturing this a new piece of keystock should be cut and placed into the slot, a set screw should be tapped through the shaft into the key to hold it in place, then a hard bolt should go through the existing hole in the shaft and tightened harshly. At the pto end there should be a collar for a shear pin of softer material. Now if there is no set screw holding the key it could wiggle loose and fall out wherupon the bolt could break, assuming it is not of hard quality. The set screws are hardened and drilled hollow at the end so it will cut into the key and hold it securly. I had to mess with a shaft on the snowblower this winter and the trouble was with a set screw that didn't do its job...good luck getting this shaft working...Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
