Re: Woodruff key on PTO
Posted by Michael Soldan on April 21, 2005 at 15:59:27 from (66.203.172.221):
In Reply to: Re: Woodruff key on PTO posted by J.D.Palmer on April 21, 2005 at 06:58:38:
JD, if you are satisfied that the key cannot move with the set up you have that is good, I was thinking that if the key could come loose and wiggle out it would be mere seconds before the bolt would shear, most keyways do have some form of set screw to keep the key in place, if your cutter has a shear then you shouldn't experience any problem with the pto shaft, yet that is what I understand is happening. A key and keyway should not wear loose or grind out if they are in tight and set, I hope you solve the problem...Mike
Post a Followup
