Re: bull pinion removal
Posted by ChadS on April 22, 2005 at 22:02:12 from (66.228.96.174):
In Reply to: Re: bull pinion removal posted by the tractor vet on April 22, 2005 at 19:49:45:
Just becareful, it does depend on which side you need to remove if your just removing one side,, if your taking off the right side, its possible for the carrier to slide off te other pinion shaft, and fall into the rear end housing, Im thinking the right side, hold the ring gear against the pinion shaft. Ive had em fall off there, and had to take the top plate off, I wasnt a happy camper when that happened. LOL! Procede with caution, git r done! ChadS
Post a Followup
