Re: Farmall 350 found in weeds; what's it worth?
Posted by Midwest redneck on April 24, 2005 at 04:19:26 from (64.136.26.225):
In Reply to: Farmall 350 found in weeds; what's it worth? posted by Ron K on April 23, 2005 at 21:07:33:
You should be able to see if the engine is stuck by getting a wrench to turn the crank pulley. I would not give more than $100 for it, if the engine is not stuck. Plus you are doing the property owner a favor by removing it.
Post a Followup
