Re: Keep getting water in rearend, where's it comi
Posted by captaink on April 26, 2005 at 08:42:06 from (66.115.214.56):
In Reply to: Keep getting water in rearend, where's it coming f posted by Bobg on April 26, 2005 at 06:58:10:
In addition to the water getting in around the gearshift lever, I would like to offer a thought on condensation particularly dealing with heating and cooling. As the air in the transmission warms, it expands and escapes through the gearshift lever tower. As it cools (usually overnight) it creates a vacuum and pulls air back into the transmission (evening air has more humidity than daytime air). Now, if the tractor is not run for a few days and the temperature outside falls to the “dew point” so will the cast iron. This will cause water drops to form on the inside of the transmission. These drops fall from the top or run down the sides into the grease, and unless sufficient heat is generated to evaporate it back out, will stay in there. The same principal applies to the inside of a steel building especially if the doors are left open on a foggy day and the temps fall overnight. If you use heavy gear lube (80 or 90 weight) you can get most of the water out of the rear end without changing the lube. After the tractor has set for a few days, the water will have settled to the bottom of the rear end. Loosen the drain plug. As you loosen the plug water will start to seep around the treads and come out first. Depending on your patience and time, you can play with loosening the plug more or less and let the water out. When the water stops coming out tighten the plug back up. If you do this once a year, you will be fine.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
