Probably sometime the starter or drive end, or case was changed to one that places the case that solenoid bolts to in a different position. Depending on drive end it may be possible to rotate case on it if it has other bolt holes. Also the solenoid can be mounted at another place with a cable from it to starter. If I was to guess, I would think someone put a row crop starter on it.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
