Re: 436 parts in 414???
Posted by Aces on April 27, 2005 at 19:46:13 from (4.164.18.5):
In Reply to: 436 parts in 414??? posted by J I Case on April 27, 2005 at 17:36:55:
JI The main difference between the DT414 DT 436 and the DT 466 is the crank but if the crank is different then the piston has to be different. The piston has to different length or it will hit the head. I would also check the oil pump.
Post a Followup
