changing drop axles on 20
Posted by Okla Kansan on April 28, 2005 at 18:48:23 from (209.240.205.63):
I started changing out the axle on my 32 as the bearing is bad (drop axle), with one on my 37 junker. I noticed that 4 of the bolt heads are inside the housing. I assume they are as loose as the ones on the outside thereby making it necessary to seperate the 1 16th plate on the inside from the casting on the out. If that be the case, then buying another bearing seems to be the better deal. Also, hows a good way to pull a froze brake drum. The otherside drop axle on the 32 is froze. I origionally intended to change them both out, take the brake rod and handle off then 37 and install it on the 32 while in the process of changing out drop axles. Guess ill pass on that if I got to seperate the housings
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
