Re: Cub still not running after carb rebuild today
Posted by El Toro on April 28, 2005 at 18:59:34 from (205.188.117.138):
In Reply to: Cub still not running after carb rebuild today posted by GNB on April 28, 2005 at 18:41:48:
You need to see which way the rotor turns. It should turn clockwise. That's the way your wires
should be connected. Starting with No1 plug near the radiator should be installed when the rotor is pointing to No1 in the cap. You may want to bring the engine up on the compression
stroke at TDC. You rotor should point to No1
in the cap. If this plugwire is right then check
No3 wire, then 4 and 2. If this is the case your wires are ok. Hal
Post a Followup
