Re: Anybody Ever Use CLR on a Radiator?
Posted by Moki on April 29, 2005 at 09:44:17 from (216.56.22.26):
In Reply to: Re: Anybody Ever Use CLR on a Radiator? posted by old on April 29, 2005 at 09:33:06:
Do you use straight vinegar, not diluted? Just let it idle for an hour or half throttle? I have an IH that gets warmer than it should under load (plowing for instance) and does not leak so this sounds like a "plan." Thanks for the suggestion and answers.
Post a Followup
