Re: HELP!! Still can't find problem!!
Posted by Hugh MacKay on April 30, 2005 at 02:23:46 from (216.208.58.191):
In Reply to: HELP!! Still can't find problem!! posted by Granger on April 29, 2005 at 23:05:56:
Granger: Since you've checked these items, only one thing left, battery cables. How large are they? 6 volt systems operate on twice the amperage 12 volt systems do, thus you need large cables. 1 gauge, with soldered on ends are what is needed. Another item I do is go right to a casting of tractor for my ground.
I had this problem years ago with my Super A, someone had installed cables from an old 12 volt car. Now you would think most any cable would turn that little SA engine, not so. I changed, and the difference is unbelievable. I find the best source for these heavy cables are heavy truck supply stores. They use these on big diesels even with 12 volt. I expect by now farm equipment dealers would have heavy cables.
Post a Followup
