Re: Hydraulic Cylinder Gurus?
Posted by Bob nor. mn on April 30, 2005 at 11:41:55 from (209.191.192.182):
In Reply to: Hydraulic Cylinder Gurus? posted by Harley on April 30, 2005 at 10:19:11:
also run the 3" ram all the way out and measure depth of oil left in tank , is there enough to fill larger 4" cyl. some tanks you can fill a little higher, otherwise you will need a larger tank.
Post a Followup
