Re: 49 M won't start
Posted by Nebraska Cowman on April 30, 2005 at 14:35:53 from (65.162.146.167):
In Reply to: Re: 49 M won't start posted by Egon on April 30, 2005 at 12:59:47:
cows? oh no! No the diagram means nothing if someone put the distributor on with the gear 180° off and then moved the wires to compensate. Take out number 1 plug and find where the piston is just coming to top dead center on compression stroke and then verify that the rotor is pointing to the spark plug wire to that cylinder. At top dead center the points should be just starting to open. the spark occurs as the points open. (that is why they are called "breaker" points and not "closure" points)
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
