Farmall Tractors Discussion Board
Re: Dual Wheels On m
Posted by Bob M on December 10, 1999 at 12:59:05 from (192.232.120.194):
In Reply to: Dual Wheels On m posted by FArmall on December 09, 1999 at 20:04:21:
My Super M ran 20+ years with duals. All 4 wheels were mounted concave side out, and with the inner set mounted as close to the axle housing as they could go. The tires on the inner set were also loaded.
Never had a lick of trouble with the transmission/rear end. Only problem was when an outer wheel's clamps worked loose and the wheel flopped around on the axle, breaking out a chunk of the wheel hub.
Post A Followup
: Re: Re: Dual Wheels On m
