Re: New Head Gasket And It Still Leaks
Posted by the tractor vet on May 02, 2005 at 06:20:18 from (4.124.92.83):
In Reply to: New Head Gasket And It Still Leaks posted by Farmallion on May 02, 2005 at 05:27:26:
What gskt did you use a Fel-PRO?? did you use Copper Coat. Did you retoqure hot ?? did you pull it to the 95 foot lbs?? and if you are using a junk Fel Pro gskt add 5 more lbs of toqure. I have had to pull them down the the diesel spec to get them to stop leaking . Just put a 706 gasser back to gether with a victor gskt. and no leaks at 95 foot lbs. And copper coat.
Post a Followup
