Re: Farmall M thermastate
Posted by captaink on May 02, 2005 at 14:23:51 from (66.115.214.56):
In Reply to: Farmall M thermastate posted by Farmallion on May 02, 2005 at 08:21:26:
I highly doubt that in an M the removal of a thermostat will cause overheating, much less causing it to foam. Anyway, I’m guessing that you had the radiator cleaned because of overheating? If so the other posts about an internally blown head gasket are likely pointing to your problem.
I doubt a crack as I would think that a crack would put a few bubbles in the radiator, not enough to cause foaming unless it was a pretty severe crack.
Post a Followup
