Farmall Tractors Discussion Board
Re: parked A for 13 years
Posted by JH on December 10, 1999 at 20:52:45 from (207.115.52.150):
In Reply to: parked A for 13 years posted by nate on December 10, 1999 at 19:43:46:
There are several methods at this site in the archives, for freeing a stuck engine. One that is not mentioned is as follows: Place an adapter in the spark plug hole which will allow you to apply air pressure into the cylinder. You can buy both sizes in one package at NAPA for under $10.00 and it is used for keeping the valves in position while changing the valve seals. This saves you from removing the head. Place a generous amount of penetrating oil in the cylinder, and apply air pressure. The air pressure will force the oil where it would not normally go, especially beyond the rings, at an exponential rate. Beware that when you remove the chuck from the adapter, oil is going to come out of that hole and all over everywhere, so stand to one side and cover the area with a rag. It took a long time to set up, it will take a long time to free, but this method will work when others will not. Good luck.
Post A Followup
: Re: Re: parked A for 13 years
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
