Re: H Farmall: Leaky Carb.
Posted by old on May 02, 2005 at 18:03:18 from (207.69.136.204):
In Reply to: Re: H Farmall: Leaky Carb. posted by lekander883 on May 02, 2005 at 17:53:12:
Pretty common with these old tractors. It will not hurt your battery/starting system if you turn it off. Just turn it on count to 30-50 and start the engine. Since they don't have a fuel pump it only takes a little while for the carb to fill any how.
Post a Followup
