Re: Reuse A Head Gasket
Posted by the tractor vet on May 03, 2005 at 07:10:42 from (4.124.82.205):
In Reply to: Reuse A Head Gasket posted by Farmallion on May 03, 2005 at 05:55:17:
It is scrap now go and get a new one and make it a victor gskt they seam to be alot better then the Fel-Pro.The one i just put on the 706 that ate a piston sealed the first time . with only a lite coat of copper coat. and a retoqure . The newer 6 cyl. are a higher comp. then the older tractors and run at a much higher rpm . Also make yourself up 2 studs from a couple of old 1/2 x4 1/2 bolts cut the heads off and cut in a screwdrive slot in them so you can remove them after you get the head on this helps with alignen the head so you are not sliding the head around on the gskt. to find the bolt holes. Make sure that you have it up to operating temp. then retoqure and reset the valves . Before you put the head on i like to use some 180 emery to make sur that the block is clean and wipe down with laqure thinner also run a tap down each head bolt hole to chase the threads and clean with either or brake clean and blow dry clean the bolts up with a wire bruch on a grinder or run a thread chaser over them clean and dry and then a littel white greaseor a light coat of oil this was you will get a better toqure also lube the washer .
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
