Re: Settle A Bet
Posted by Nebraska Cowman on May 03, 2005 at 10:37:46 from (65.162.146.167):
In Reply to: Settle A Bet posted by gobs on May 03, 2005 at 06:41:03:
OK, I'll be a wise a$$ and settle your bet. No, putting in a thermostat backwards will not make the engine overheat. It is running the engine with the cooling system blocked that will make the engine overheat. The backwards thermostat can set there backwards for years and unless you apply heat to the sensor side it will never "do" anything.
Post a Followup
