Re: Farmall M Lighting Trouble
Posted by janicholson on May 03, 2005 at 13:09:58 from (199.17.6.175):
In Reply to: Farmall M Lighting Trouble posted by chadd on May 03, 2005 at 08:49:54:
The others have the thrust of it, here is one more tidbit. With the bulb in, and the lights on, use that volt meter of yours to probe the socket/connection to check for ground faults. use a light bar bare spot, ot thread edge to ground the black lead, then probe into the fixture to look for volts. touch the housing, then the socket, then the exposed brass of the bulb. If nothing shows up, the ground side is probably good. Pull the bulb and reach into the socket with the red probe. If ~6v it should work if not I would check to see if there is a rusty connection at the Plus terminal on the outside. if the volts showing at the terminal are low, and the connection at the switch is clean, I would replace the wire. Connect the new wire to the end of the old one with small shrink tubing (use 2", and heat well to bind them in the tube)then pull/push and curse the new wire into place, crimp on new connectors, and illuminate. JimN
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
