Re: SA hydraulic problem
Posted by scotty on May 04, 2005 at 04:49:49 from (199.231.49.128):
In Reply to: SA hydraulic problem posted by mchief on May 03, 2005 at 23:32:33:
Mchief,
You need to get the rebuild kit for the touch control, and with that kit you will get the orings needed to rebuild the pump. The driven shaft in the pump has an oring riding on the front part of that shaft. If the shaft has a groove worn in the section, that is probablly were the hydraulic fluid is leaking back into your crankcase via thae timing cover.If that is the case, you will need to replace that shaft.
scotty
Post a Followup
