Re: ID Plow
Posted by Hugh MacKay on May 04, 2005 at 14:43:00 from (209.226.106.186):
In Reply to: ID Plow posted by Moki on May 04, 2005 at 09:32:02:
Moki: Plows are quite hard without a photo, can you post one. If not send me an e mail. I have a good photo of a No. 8. I will warn you it is a Canadian plow. The only real difference between Canadian and US built plows is the Canadian plow has perpendicular cross members between beams while the US plow has diagnol cross members between beams. A 3 bottom Little Genius No. 8 may have a solid steel beam, diagnol across the top of all 3 beams. If the plow is the newer No. 60 or 70 it will have a diagnol box beam across all beams. I don't have any photos scanned on the 60 or 70 plow.
Post a Followup
